588,285 active members*
4,301 visitors online*
IndustryArena Forum > Community Club House > Need a bit of help on first cut CAMBAM,Mach3
Results 1 to 4 of 4
    Mar 2011
    13
    Hi all, built a wood router in my shop and I am at the point to just draw a circle with a pencil. When I load the road runner it draws the first 500 lines fine, but
    when I load the following code i get "Radius to end of arc differs from radius start line 12". I am just wanting to practice with CamBam and Mach3 untill my FUN budget
    allows for the full license. Any direction would be awsome
    Aaron
    ( Made using CamBam - CamBam CNC Software )
    ( Untitled 5/21/2011 11:13:40 AM )
    ( T0 : 0.01 )
    G20 G90 G64 G40
    G0 Z0.125
    ( T0 : 0.01 )
    T0 M6
    ( Profile1 )
    G17
    M3 S1000
    G0 X1.0128 Y0.0
    G1 F10.0 Z-0.015
    G3 F30.0 X-0.5064 Y0.8771 I-1.0128 J0.0
    G3 Y-0.8771 I0.5064 J-0.8771
    G3 X1.0128 Y0.0 I0.5064 J0.8771
    G0 Z0.125
    M5
    M30
    Mar 2011
    13
    Hood Helped me, Thanks
    Hood told me to set IJ Mode to Incremental and it worked
    Mar 2003
    35538
    Change your IJ mode to incremental.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Mar 2009
    45
    getting the same error with Mach3
    Sorry, I can't help you. I'm getting the same error after gcode conversion in LazyCam of a triangle pocket with two arcs on opposite corners. I'm using a Canned gcode project that came with lazy cam.
    Any help for this problem would be appreciated.
  1. CAMBAM/MACH3 - no rapids...
    By wildwhl in forum CamBam
    Last Post: 03-11-2011, 07:36 AM
  2. Safe Z in cambam but not in mach3
    By bfcg in forum CamBam
    Last Post: 08-12-2010, 01:30 PM
  3. Is Mach3 best/only choice with CamBam?
    By Mecmac in forum CamBam
    Last Post: 02-05-2010, 03:51 AM
  4. what is CamBam?
    By cncadmin in forum CamBam
    Last Post: 05-02-2009, 01:41 AM
  5. Will CAMBAM run in Win 98 ?
    By epineh in forum CamBam
    Last Post: 08-03-2007, 06:50 AM
