Anyone know of a good book I can use to learn simple G code from scratch. If you could add the ISB No. , I think that's what they call it, that would be grand. Thank you
Both the mach3 manual and EMC manuals have pretty good explanations, and you can always ask questions here. Sorry, I don't know of any books. But I've seen links posted with g-code info before.
Gerry
UCCNC 2017 Screenset
Mach3 2010 Screenset
Here is a previous link for two I found that are really good.
http://www.cnczone.com/forums/showth...ghlight=puszai
The ISBN is 0-13-156084-0 and 0-8273-3782-5
There is a free simulator called MicroTech that you can run the code on.
http://www.cncsimulator.com/
Al.
Albert E.
I cannot recommend any book but here is a very useful link:
http://technology.calumet.purdue.edu/met/mfet/275/
It is an entire online cours and you can download and save a lot of the information.
got to http://www.cncci.com they have great programming books. That is how I learned
No matter how good you are, there is always someone better!!!
Peter Smith Books
Good luck
Jorge
My advice is: YES, get to learn G&M code first, the fanuc post type, which is popular with most the new cnc's and software such as Mach3. The old Bridgeport post, where they swing the archs from absolute zero is outdated.
Then get into cad cam as soon as possible, for many reasons. In cad cam, you get what you pay for, so if money is a issue, try to buy a older, used version, like Mastercam ver8, from someone that upgraded, you will never be sorry.
OK, First, not that I'm bragging or being a jerk, but I have an A.S. in Computer Aided Drafting And Design, so CAD is noooo problem. I can draw just about anything in 2D or 3D. What I think I need to know G code for, is,positioning my piece part to set up and start machining in Mach 3. I have V Carve Pro to do the CAM end, but I just can't get the machine to go in the right direction. One big problem is, after I set my part zero, top surface of material, what do I do next???
So after I clear my Z axis of hitting anything, It's cycle start and I'm good to go
I think jorgehrr means Peter Smid. His books are excellent
CNC Programming Handbook ISBN 0-8311-3158-6
CNC Programming Techniques ISBN 0-8311-3185-3
Fanuc CNC Custom Macros ISBN 0-8311-3157-8
Speedre
The CNC Workshop by Nanfara,Uccello and Murphy Found it on EBAY AROUND $30.00 and has a CD interactive simulator look's like trade school entry level and has easy to understand examples and all the standard G&M codes Good Luck Kevin
Thanks to all, I guess it's off to the book store. Again, thank you all.
Free DXF - vectorink.com
