603,968 active members*
2,079 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Need disconnect for powerfeed
    May 2006
    18
    I'm a relative newbie machinist, doing limited quantity manufacturing of small parts. I recently bought a X2 benchtop mill and added a DRO and a x-axis powerfeed.
    The x-axis powerfeed is REAL handy, but it totally sucks when I want to crank the x-axis by hand, as the powerfeed adds a lot of resistance to the handcrank. I would really like some sort of quick disconnect coupler that would allow me to freely rotate the handcrank, yet quickly get the powerfeed back in operation.
    I would love to hear some ideas on a coupler or maybe even a new powerfeed.
    thanks
    Mar 2003
    4826
    That sucks. The more expensive power feeds for mills have a built in clutch which disengages the power feed. I've seen these units for $350 but they are made for larger mills, and may be too bulky to fit your application.
    You'd have to open up the coupling on yours, with some sort of face jaw clutch, but you would need to create a bit of a slideway and a thrust device to allow for engagement/disengagement in place of the solid coupling. To make this all 'handy to use' would be quite a challenge. Sounds like a lot of work.
    First you get good, then you get fast. Then grouchiness sets in.
    May 2006
    18
    Quote Originally Posted by HuFlungDung View Post
    ........some sort of face jaw clutch, but you would need to create a bit of a slideway and a thrust device to allow for engagement/disengagement in place of the solid coupling. To make this all 'handy to use' would be quite a challenge. Sounds like a lot of work.
    Yeah, I was thinking along same lines, but it seems like too much work. I'd rather just spend the $350 and get one already made up, if possible.
    thanks
  1. Poor Person's Powerfeed?
    By BrendaEM in forum Benchtop Machines
    Last Post: 03-01-2007, 02:21 AM
  2. X Axis powerfeed clutch adjustment
    By Stinson_Voyager in forum Tree
    Last Post: 12-27-2006, 12:31 PM
  3. sizing main disconnect
    By 69owb in forum CNC Machine Related Electronics
    Last Post: 04-01-2006, 11:00 PM
  4. how do I disconnect microswitch?
    By jeremyinnys in forum CNC Machine Related Electronics
    Last Post: 10-12-2005, 04:40 PM
  5. Fanuc 21-GA_416 Alarm-Axis Disconnect
    By lasermike in forum DNC Problems and Solutions
    Last Post: 03-10-2005, 07:49 AM
