603,914 active members*
3,345 visitors online*
    Feb 2004
    2337
    Need to do a 3d model of a horse.
    My 9 year old daughter ( Amelia ) is horse crazy. ( Comes with the age I guess)
    She has been hassling me to route her a horse plaque.
    My problem is I wouldnt know where to start. Does any one have any gcode of a horse that I can use?
    If you can upload it into this thread we would both appreciate it.
    Being outside the square !!!
    Mar 2003
    35494
    Not sure if this will work for you. I got it at 3DCafe. I converted it to .stl for you. You'll probably have to scale it up.
    Attached Files Attached Files
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Mar 2003
    779
    Here is a horse relief. It might be a bit hard to cut the true 3D horse. I can also get you a Pegasus.
    Jeff Davis (HomeCNC)
    http://www.homecnc.info
  1. Taking Delivery on Techno-Isel 4'x4' 130 Model
    By mtuckf in forum Commercial CNC Wood Routers
    Last Post: 03-23-2005, 03:20 PM
  2. 1/5 scale Model A engine
    By woodythx13 in forum I.C. Engines
    Last Post: 12-17-2004, 09:16 PM
  3. RFQ closed - scale model machined auto wheels needed
    By joemartins in forum Employment Opportunity
    Last Post: 10-27-2004, 02:16 PM
  4. Looking for someone to do 3-d model
    By seansear in forum Employment Opportunity
    Last Post: 08-13-2004, 09:39 PM
  5. Solid model to CNC code quession
    By mikenelson in forum Uncategorised CAM Discussion
    Last Post: 07-08-2003, 03:55 AM
