haveing problems dont know if it the brakeout board a MB02 v6 or the drivers cw250 cousing the problems only could get one driver going Z 6,7. pluged all other steeper motors in to ths driver conected to 6,7 x,y,z,a,b steepers worked then pluged z driver into 8,9 it worked so i asumed all other pins where ok tested a,x drivers in 6,7 they did not work other than z.
went to test y axis in 6,7 did not work at the same time i put z driver into 2,3 and it did not work put z driver back into 6,7 and still did not work i think i have jummpers set correctly.
i have jp1 override in lo, hi, cp. got jp2a set to output, jp2b set to system enable, JP3 Common terminal Polarity Jumper set across pins 2,3, jb4 pulled-up to 5V, nothing in jp5, jp6 pulled up and jp7 pulled up.
is this correct all steeper drivers where wired correctly, power supply good, 5v for brakeout board from computer 5v.so help please. the steeper drivers are cw250.
help me or i shoot the machine
