587,172 active members*
3,304 visitors online*
Thread: need help
    Nov 2014
    74
    Question need help
    Been stumbling around trying to find the answer to a problem I have created a wrapped job set and then try to import a 3d relief stl to wrap it around the cylinder, its set to wrap the x values around the Y which I know is correct when I go to unwrap the the stl it becomes all distorted and cannot make out what its suppose to be I hope someone can guide me along to what it is I'M doing wrong
    Steve
    Nov 2014
    74
    Re: need help
    Nobody?
