586,072 active members*
4,439 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Need help! 003 fanuc too many digits
    Good morning all, I'm on a Vtl with Fanuc18i-TB. I've been trying to manually touch tools off on the X diameter of an id to no avail. It will allow me too cross centerline and touch off negative numbers but not positive for I'd which in turn really limits my tooling capabilities. The machine came from England a few years back and I don't know if they changed parameters. Any help would be greatly appreciated! Jeff
    Aug 2019
    145
    Re: Need help! 003 fanuc too many digits
    Hello,
    A little more information please.
    What step are you doing when the alarm is generated?
    -Running an auto program.
    Line where the alarm is generated.
    Is the alarm generated in single block.
    -Manually entering data
    Screen and field when entering the data.
  1. Alarm 003 to many digits on Hardinge with 18-T
    By HBFixedGear in forum Fanuc
    Last Post: 08-10-2022, 01:45 AM
  2. Fanuc OM-D 003 P/S Alarm problem
    By chris661 in forum Fanuc
    Last Post: 12-03-2011, 01:16 AM
  3. Replies: 2
    Last Post: 04-08-2011, 09:03 AM
  4. Too many digits
    By vmcchris in forum Fanuc
    Last Post: 08-20-2010, 12:45 AM
