Dear sirs,
We have a turning center machine marked MIKRON.
The machine has MOCON (Motor control board). I had a problem, The problem was coolant pump not work. We solved the problem. But after assembled the board on machine, during to go zero points, It is beginning to give 103, 105, 106 messages. The messages are X,Z,A servo error too large.
Y axis is not using. There is no problem on servos. Depend on user manual explanation of the error is "Too much load or speed on axis motors. The difference between the motor positions and the commended position has exceeded a parameter"
In my opinion there is a parameter problem. But I don't know How I can load the parameters on MOCON board. Can anyone help me about the problem.
With my best regards.
Tayfun Kusluoglu
__________________
