587,201 active members*
3,157 visitors online*
IndustryArena Forum > CAD Software > Rhino 3D > Need help - AK 47 Receiver
Results 1 to 10 of 10
    Apr 2012
    27
    Im very new to cad and really into guns. I would like to mill my own ak 47 receiver. Ive been tinkering in Rhino and still have no clue where to start. Do I make a rectangle and hollow out the center? Make separate walls and shapes and attach them at the end? Im so stumped. I included some pics of a machined receiver so maybe someone could point me in the right direction on how to start this project.:violin:
    Attached Thumbnails Attached Thumbnails 22614-12.jpg   22614-1.jpg   22614-11.jpg
    Jun 2008
    467
    Lightbulb A visit to the wizard might be in order
    Quote Originally Posted by hugh jass View Post
    Here is little something to get you going in the right direction, just be careful you don't shoot yourself in the foot.
    JoeyB
    Attached Files Attached Files
    A doughnut a day keeps the doctor away.
    Feb 2006
    174
    There is not one single answer to your question. In Rhino there are always multiple ways to build such pieces, and you should try both the ways you mentioned as a learning experience. If you run into trouble, then ask again.
    Lars
    Feb 2010
    Hello-
    I would agree- you can do things both ways as suggested. In this case I would draw up each face or elevation to scale. And not worry yet so much about the fillets/radiused edges and countersinks regions. Once you draw these up in 2d I would recommend messing around with the planarsrf command to build up the surfaces using your linework. To test this out just draw a rectangle and then type into the command line planarsrf this will make a plane- then once you have most of the surfaces defined in 2d you can rotate and move the planes into the right axis and put them together.
    Once you get this together you can then move on to chamfering for counter sinks and fillets.
    Subtracting from a solid can work but you may end up with issues trying to Boolean certain things. Post if you get stuck and I'll take a look.
    Dec 2010
    Apr 2012
    27
    Thanks alot! Im working on my own design for it but I still need the dimensions for the front trunnion. The one the barrel presses into. mm's are fine.
    Apr 2007
    663
    for something like this alibre or solidworks deserve a look, or some of the other 3d parametric cad programs, some free, that have appeared in last year or so
    Jun 2004
    6618
    I use TurboCad and I think I would start with a block. Shell it. Then draw a few features that you could push and pull the surface of. You can easily add and subtract portions of elements. I make good use of construction lines. They make it easy to place parts in a 3D element. Lastly I would dress the edges as needed. Extrude is another tool I use often.
    Lee
    Apr 2003
    1357
    You don't need other programs to do this if you have Rhino 5. You can shell, you can push & pull (with the gumball and sub-object selection), etc.
    Dan
    May 2013
  1. suggestions for gun receiver engraving
    By ErnieKim in forum MetalWork Discussion
    Last Post: 03-14-2012, 08:35 PM
  2. need help Differential Driver/Receiver circuit
    By markus_detroy in forum Servo Motors / Drives
    Last Post: 04-18-2008, 03:02 AM
  3. Full Auto BB Gun Receiver
    By mikkojay in forum Hobby Discussion
    Last Post: 01-27-2008, 09:49 PM
  4. Touch probe to ir receiver??
    By REVCAM_Bob in forum CNC Machine Related Electronics
    Last Post: 04-28-2007, 02:43 AM
  5. Help with new Receiver
    By HomeCNC in forum Hobby Discussion
    Last Post: 11-17-2004, 12:49 AM
