587,101 active members*
4,096 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Need help in buying proper cnc machine
Results 1 to 11 of 11
    Feb 2007
    Question Need help in buying proper cnc machine
    I came very close to buying the Craftsman CompuCarve but after a visit to the web site I found there are many unresolved issues,although they seem to be woking with customers to get the bugs out.What sold me was the ease of using their software.The software issue has kept me from adding a cnc router to my woodshop.I would like some professional advise on a good cnc router with easy to use software that would be used more than just a hobby as the compucarve would be. My budget would be about 12,000.
    Thanks for some help.
    Check out our website and download out catalog, I'm sure we have something that will fit your application.
    www.Torchmate.com
    Mike @ Torchmate.com | www.Torchmate.com
    Toll Free : (866) 571-1066 M-F 7:30am-4pm PST
    Mar 2003
    35538
    ShopBot.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Nov 2004
    436
    With a budget of $12000, you should not be looking at the compucarve. You could be set up and running a shopbot, with rhino and rhino cam, and mach 3. With compucarve, I believe you HAVE TO use their cad software. This is no good, as you will definately be limited by hobby/cookie cutter-cad-software.
    My router cost me about $9000 to build ($4000 was labor), and it cuts nicely at 120 IPM, is very rigid and accurate (+/- 0.003"), with a work envelope of 24 x 60 x 5.5". That leaves $3000 to play with. Rhino and Rhinocam, with mach 3, fit the bill nicely and you can draw and carve most anything you can imagine.
    The CC is definately not built for production use, built much more like a printer (lots-o-plastic).
    This is one of the most rewarding investments you will ever make. Good luck with your choice.
    Feb 2007
    11
    Thumbs up You would be money ahead........
    You would be money ahead to buy a home-built off eBay for $1,000 less than the Sears machine, if you are just looking for a learning tool. However, once I got bitten by the "bug", I travelled to 4 different manufacturer's locations to see and "feel" their machines. I also got information on 3 more. I finally purchased a Shop Sabre. I went all out and purchased a 4' X 8' machine with all the bells and whistles including a 4th axis unit for about $25,000. However, they have VERY nice machines in your price range. Their support, both before and after the sale, has been tremendous and the machine has never faltered.
    I still have a lot to learn about this machine and the software, but I'm learning more each day. What I would really like to do is find some classes that are specific to the CNC router. The classes in my area are confined to mills and lathes. While these are similar, they don't touch on many of the aspects of the router table.
    Good Luck.
    May 2005
    674
    As much as I dislike the design of the shopbot (v-rollers, angle iron rails, rack & pinion, oh lord), it does work decently. For $12K, get yourself a PRT Alpha 96 with table (don't build the table yourself... it's a waste of time). Final price will be right at the $12K mark.
    Plan your budget for the next few months to add
    1.) Spindle - Colombo
    2.) Vacuum Table
    The Sears Compucarve is an absolute joke. It's almost as bad of a gimmick as the "dual drill". For Christ's sake, it uses a feed roller for the X-axis.
    Nov 2005
    6
    Please consider this machine http://www.tigertec.us/images/6090-2.jpg
    240 ipm rapids, 120 ipm cuts, very quiet spindle. Price includes PC and Mach3
    David @ tigertec.us
    Mar 2005
    18
    Quote Originally Posted by Zumba View Post
    Naah.
    It works great, it's affordable, and it's got great support. Obviously, you haven't seen one.
    Your pal,
    Meat.
    May 2006
    12
    Zumba,
    You hit the nail on the head! The compucarve is basically a printer with a router bit.
    I'm sure it has it's place, just not in my shop.
    The shopbot is a good answer. A beefy version of the shopbot is the MechMate. $4,000.00 range if you are handy with your hands.
    DocTanner
    Mar 2005
    18
    Quote Originally Posted by DocTanner View Post
    Zumba,
    Yep; just like every CAD/CAM machine out there. Your point?
    Your pal,
    Meat.
    Apr 2007
    66
    Compucarve...no joke
    Quote Originally Posted by meat View Post
    Naah.
    Your pal,
    Meat.
    Hello,I'm getting ready to purchase 60 x 96 techno router,but let me say this about the compucarve...it is not a gimmick nor a joke.While not a real cnc it does do very accurate carvings, letters,signs and many other things...no it's not going to cut cabinet parts...that's why I'm getting the big machine.The carvewright /compucarve is very versatile and I will continue to use it along with a CNC.
    Ben
  1. Buying a 3in1 Plasma/Tig/Stick welding machine
    By kheri in forum Waterjet General Topics
    Last Post: 05-13-2009, 11:27 PM
  2. Replies: 1
    Last Post: 12-27-2006, 09:54 PM
  3. help buying new benchtop machine
    By c-fex in forum Benchtop Machines
    Last Post: 11-15-2006, 07:56 PM
  4. CNC World-Buying time on a machine
    By asvand in forum Commercial CNC Wood Routers
    Last Post: 02-14-2006, 10:33 PM
  5. Proper ways to fuse your machine electronics
    By freak_brain in forum CNC Machine Related Electronics
    Last Post: 07-17-2005, 02:55 AM
