603,967 active members*
1,983 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Need help calculating steps per unit (rack and pinion)
    Feb 2007
    167
    I have 1.8 degree steppers being run by 10 microstepping drives.
    I have 24 tooth, 20 pitch, 1.2" diametrical pitch spur gear attached to the motor
    This runs on a 20 pitch 14.5 degree pressure angle rack
    Can someone calculate my steps per inch as I simply cant figure out the formula :x Thanks so much!
    Jul 2007
    887
    If the diametral pitch of the spur gear is 1.2" then the "traveled" circumference is 1.2*Pi or 3.7699". So, 2000 steps = 3.7699" and 2000/3.7699 = 530.218 steps/inch.
    EDIT: OR....when I think about it, diametral pitch might actually mean "traveled" distance per revolution of the gear and if that is the case then it's 2000 / 1.2 = 1666.667 steps/inch instead. Sorry for the confusion.
    /Henrik.
    Feb 2007
    167
    I did a steps per unit calibration with Mach 3 and my it suggested 533.33 so I think your first answer is correct. Thanks a ton for the help! Appreciate the fast response.
  1. calculatiing pinion size for rack and pinion setup
    By Apples in forum DIY CNC Router Table Machines
    Last Post: 08-06-2015, 11:18 AM
  2. Calculating Steps with Xylotex Board
    By cxixer in forum Machines running Mach Software
    Last Post: 05-19-2008, 02:10 PM
  3. Need help on calculating steps
    By rustamd in forum Mach Software (ArtSoft software)
    Last Post: 08-03-2007, 01:08 PM
  4. Calculating steps per revolution
    By watsonstudios in forum Mach Software (ArtSoft software)
    Last Post: 06-25-2007, 07:22 PM
  5. Calculating "steps per unit" for rotary axis?
    By Beezer in forum Mach Software (ArtSoft software)
    Last Post: 11-28-2004, 10:31 PM
