After reading up on the thread of "TB6600 drive from eBay", I was wondering what I had over here.
Bought off of Banggood, at 7 or 8 USD I think. So being a newbie, nothing to go wrong with for first try. If it goes up in smoke, lesson learned...
Anyhow, tested this weekend first time on the Z-axis of my Router in Progress, and works all fine.
So today decided to take it apart and check what's inside.
1. Sure no TB6600.. But it is a Toshiba IC (if it's not a fake/copy)
2. Found the full details:
TB67S109AFTG | Motor Drivers | TOSHIBA Storage & Electronic Devices Solutions Company | Asia-Pacific
3. It seems to really be a 4A Driver, but no clue to its capabilities yet..
4. With the little bit of testing it got hot very fast.. There was a very thick thermal-pad, then a small block of aluminium, then some heatsink past (way too much) and then the board on it.
So that needs to change anyway. Good to open up stuff.
Some pictures and full description can be found here:
TB6600 Upgraded Version 32 Segments 4A 40V 57/86 Stepper Motor Driver Sale - Banggood.com
http://www.cnczone.com/forums/attach...d=332162&stc=1
Given the data-sheet, and 2 capacitors rated at 50v max, (470uF) could I give this board 45v?
Currently running from a 36v PowerSupply.
Will put all 4 drives on a huge heatsink.. think I still have some old G5 towers at work. Those heatsinks would be perfect to use..So heat should then not be an issue.
Just wondering about everything else for these drivers. Anybody have any experience with these?
Thanks and regards,
Luc
