603,979 active members*
1,359 visitors online*
IndustryArena Forum > CAD Software > Autodesk > need help in creating outline
Results 1 to 5 of 5
    Sep 2006
    5
    Smile need help in creating outline
    Hi! I'm new here in CNCZone and this my first thread and sorry to bug you people with some question about on how to create just the outline of an image or silhoutte to be used as a pattern or pathline for my Torchmate driver module? BTW, I am using an Adobe Illlustrator CS2, although I know how to trace but when I tried to export the bmp file to dxf and opening it on my TM driver software it shows error that says "no executable image". AutoCad works fine but the parts of the pathline for cutting were broken. I would really appreciate all the help I get here on CNCZone, thanks.
    Mar 2003
    35494
    Use the spline command and trace with a single complete spline. Use a lot of points while tracing, and you can adjust the spline once it's drawn by moving the grips. When done, save as V12 .dxf
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Sep 2006
    5
    Smile
    Hi ger21, pardon my late reply, anyway thanks to the input, appreciate everthing here in CNCZ. I actually made my drawings and scanned images to work on my CAD software by using CorelDraw12. If other have the same problem just like me, well i could be of help. Thanks again.
    Mar 2006
    45
    i insert the jpg/bmp image as a raster image and then go through and spline the outline... it ain't quick, but it works
    Oct 2006
    17
    One thing to remember when exporting dxf's into the Torchmate driver software from other Cad modules is the control of cut order. Uncle Buck there are some options in Torchmate cad that can speed up the process.
