603,890 active members*
4,208 visitors online*
IndustryArena Forum > CAM Software > Vectric > Aspire > Need help deciding on how to set up tool paths for a complicated vector graphic
    Mar 2010
    170
    Right from the start I wanted to do this as a series of profiles and pockets, but the more I looked at it (the frame area, particularly), the more confused I got as to how I would do that. Eventually I just extruded the vectors, capped them and turned it into a 3D model, which I cut at about 16 x 13 inches. I used three different sized bits, from 1/8" for roughing to 1/32" for a second finish pass, but the G code has the machine acting like a sewing machine, bobbing up and down as it moves across the image, and the end result was rough. Not terrible, but not professional looking, either. I think that sweeping cuts along the vectors would solve this, but I need advice on how to set it up. Particuarly the frame area, where the vectors are all closed and fairly close together, but not uniformly so, and I need to carve out the area between the vectors (outside the individual vectors), and not within them, leaving those areas raised. Because they aren't uniformly spaced, I can't just tell the router to profile around each one as it won't get everything. Any thoughts on this?
    Mar 2003
    35494
    Re: Need help deciding on how to set up tool paths for a complicated vector graphic
    Draw another vector around everything and pocket that vector, with all the detail vectors as islands.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Mar 2010
    170
    Thanks Gerry. Having played around with that, it looks like I either need to scale it up and cut it out of a larger panel, or get some really tiny bits!
  1. Saving tool paths
    By jcv1114 in forum Vectric
    Last Post: 12-09-2012, 07:46 PM
  2. Complicated geometry, wacky tool paths
    By lennys in forum BobCad-Cam
    Last Post: 05-07-2012, 10:56 PM
  3. 3d tool paths offset from 2d
    By kesparate in forum Mastercam
    Last Post: 09-18-2009, 04:28 PM
  4. 3d tool paths
    By ginamc in forum OneCNC
    Last Post: 03-19-2005, 06:17 PM
  5. Tool Paths
    By WOODKNACK in forum G-Code Programing
    Last Post: 04-27-2003, 02:09 AM
