588,648 active members*
5,872 visitors online*
    Sep 2010
    NEED HELP FAGOR 8025 TG 064 ERROR
    I have been struggling with this problem for a while and cant seem to get much help anywhere. I am new to this site and hope someone can help me out. I have lost the 24v power and was told to check the e-stop circuit and power supply. The e-stop swich is new, the power supply is new and still no 24v. I have checked the overtravel switches for each axis and they are good. I have traced the 24v output wires to the terminal strip and no 24v there, so I pulled everything off that required 24v and then I had 24v. I then started conecting them back up one at a time until I lost the 24v. When I hooked up the I/O 1 I lost it, I pulled it off and hooked up I/O 2 and lost it. So I dont know where to go from here, is it in the control somewhere on a board or is it something else? I dont know where else to look? Any help would sure be appreciated.
    Jun 2010
    On my machine, the I/O 1 is for the e-stop circuit.
    Sounds like something is grounding it out... Maybe the new switch has a different wiring pattern than the old one.
    If you can check the PLC screen, it should tell you what you use those wires for. If not, my guess would be call the machine manufacture.
  1. Fagor 8025
    By rosli in forum Post Processors for MC
    Last Post: 11-17-2011, 10:40 PM
  2. Fagor 8025/ accuslide error 099, M-tables lost
    By Tinmuk in forum Controller & Computer Solutions
    Last Post: 07-25-2009, 04:45 PM
  3. G-Code on Fagor 8025
    By midnightrambler in forum Fagor Automation
    Last Post: 02-09-2009, 10:53 PM
  4. Fagor 8025 parameter help
    By Oregon Rich in forum Fagor Automation
    Last Post: 01-27-2009, 04:56 PM
  5. fagor 8025 threading
    By Rivet head in forum Uncategorised MetalWorking Machines
    Last Post: 09-24-2005, 12:25 AM
