603,783 active members*
2,605 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Need Help! Fanuc Alarm 1400, 607, 613, 9004
    Sep 2018
    38
    Machine: 2008 Sharp SV-2412
    Control: Fanuc Oi Mate-MC
    Alarms: 1400 SPINDLE ALARM
    607 X AXIS:CNV. SINGLE PHASE FAILURE
    613 X AXIS:CNV. SINGLE PHASE FAILURE
    607 Y AXIS:CNV. SINGLE PHASE FAILURE
    613 Y AXIS:CNV. SINGLE PHASE FAILURE
    607 Z AXIS:CNV. SINGLE PHASE FAILURE
    613 Z AXIS:CNV. SINGLE PHASE FAILURE
    9004 SPN 1 :INPUT FUSE/POWER FAULT
    I boot up normally, get the 607 and 613 codes, then after maybe 20 seconds a breaker trips and I get the 9004 code. The servo drive has a normal status until the 9004 code trips, then the LED on the servo drive gives ALARM 04.
    Any thoughts on how to diagnose this? I was making chips last night, nothing out of the ordinary. I power up this morning and this is what I get.
    Thanks for any advice,
    Max
    Dec 2009
    1118
    Re: Need Help! Fanuc Alarm 1400, 607, 613, 9004
    you should check your power supply unit,should have a fuse to replace.
    Dec 2015
    214
    send us drive(bisvsp) only to my company CNC TECH SERVICES (RAJPURA) INDIA we will repair this drive on same its hardware problem so if in case its not hardwae issue i will definately help you here but its hardware issue you need to send us company we will repair this on same day.
  1. Alarm 9004....need help
    By mattpatt in forum Fanuc
    Last Post: 02-09-2021, 07:40 AM
  2. 1400-5A vs 1400-5C CPU board
    By goveng in forum Fadal
    Last Post: 04-17-2018, 10:28 AM
  3. More blocks/sec from a 1400-5 vs. 1400-4?
    By mflux_gamblej in forum Fadal
    Last Post: 06-27-2017, 03:58 PM
  4. Replies: 0
    Last Post: 08-12-2013, 09:12 AM
  5. Replies: 6
    Last Post: 03-13-2013, 03:32 PM
