603,314 active members*
1,812 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Coding > Need help with figuring "I" and "K" for radius
Results 1 to 4 of 4
    Is there a formula to figuring "I" and "K" to find the radius instead of using "R"?
    Re: Need help with figuring "I" and "K" for radius
    Maybe I should add more details. I'm using a Haas CNC lathe. I'm trying to figure and arc, but I don't want to use "R", I want to use "I" and "K" in a G03 code.
    Dec 2008
    3211
    Try this PDF from HAAS training
    arc example start at page 38
    link
    Thanks!
  1. Replies: 0
    Last Post: 02-04-2014, 02:06 AM
  2. Replies: 5
    Last Post: 01-12-2014, 07:07 PM
  3. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
