603,795 active members*
3,008 visitors online*
IndustryArena Forum > Community Club House > General Off Topic Discussions > Need help with Filament Winding Formula Calculations
Page 2 of 2 12
Results 21 to 24 of 24
  1. #21
    Re: Need help with Filament Winding Formula Calculations
    Quote Originally Posted by Jim Dawson View Post
    Take a look at this forum post. https://www.rocketryforum.com/thread.../#post-1689467
    Where it talks about ''P='', I think that this gives you the dwell in seconds that can be converter to an angular position advance based on the spindle RPM. Or in the case above Spindle RPM = 29.8, thus 360*29.8= 10728 degrees/Min or 178.8 degrees/second.
    As best I can tell, it looks like your controller requires a G4 dwell parameter that must be in degrees rather than the normal P= milliseconds or seconds.
    Short of replacing your controller with a more standard CNC controller I don't know how to get around this.
    Hi Jim,
    Apologies for the late reply, I have been busy as of late. I finally got some down time.
    I can definitely add a dwell time in seconds. I am going to do the math and I will let you know if I get some good results later today.
    Thank you for your help
  2. #22
    Hi Jim,
    It has been awhile. I did not get any good results and in the end I decided to swap out the current controllers with better controllers and to have use of a better software.
    I will be using LinuxCNC. I heard it is great and after seeing some DIY youtube videos of filament winders that use LinuxCNC, it goes to show that it will work for the task at hand.
    I don’t have the controllers in yet so I don’t have much to work with. My priority is getting LinuxCNC installed in a computer.
    Do you happen to know a thing or two about LinuxCNC?
  3. #23
    Dec 2013
    5720
    Sorry, I know nothing about LinuxCNC. The good news is that there is a lot of support for it in the various user forums.
    Jim Dawson
    Sandy, Oregon, USA
  4. #24
    Thank You Jim, I greatly appreciate it.
Page 2 of 2 12
  1. Carbon filament winding software?
    By drunkbilly in forum Uncategorised CAM Discussion
    Last Post: 06-16-2017, 03:18 PM
  2. Filament winding Gcode
    By tomocnc in forum G-Code Programing
    Last Post: 01-04-2015, 04:56 PM
  3. I from Russia. Me interest filament winding machines
    By necom in forum Community Club House
    Last Post: 06-07-2012, 05:55 AM
  4. Replies: 0
    Last Post: 01-27-2012, 11:27 AM
