587,101 active members*
4,751 visitors online*
    Jul 2009
    Need Help! File Conversion Needed
    Hi All,
    This is my first post but from just looking at the forum I know that someone will have the answer here.
    I am trying to convert ".nc" files to other files as I have a MasterCamX3 software package but the Mill I am trying to use is an XYZ Mill and will only see the following files:
    .PT4
    .MX2
    .MX3
    .GCD
    I've been looking for a software convertor or similar but haven't found anything as yet.
    Hoping someone will be able to help!
    All the best
    phil
    :cheers:
    Feb 2007
    4553
    Post
    Phil,
    Try saving and running as a .cam file If your post processor wont save in the other file formats.
    Please post your progress.
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
  1. File conversion needed MC9 to dwg/dxf
    By babinebruce in forum Mastercam
    Last Post: 07-24-2009, 09:19 PM
  2. dwg file conversion
    By Hiredgun in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-17-2008, 02:08 PM
  3. file conversion
    By chuy in forum Mastercam
    Last Post: 09-02-2008, 04:13 AM
  4. Linux/EMC file conversion help needed
    By raytor in forum LinuxCNC (formerly EMC2)
    Last Post: 04-26-2005, 05:32 PM
  5. File conversion
    By signIT in forum Uncategorised CAM Discussion
    Last Post: 06-13-2004, 11:55 AM
