587,997 active members*
1,524 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Need help getting parport to work, works fine under linux.
    Apr 2006
    40
    Hello,
    My parallel port card works fine under linux, but I wanted to try out Mach3, so I booted into windows, and parport shows up in device manager fine, but I can't get any inputs/outputs to show up on diagnostics page. Any ideas? The base address I use in linuxcnc is 0xDCA0, and this is what also shows in device manager. The card is a Syba SY-PCI10002 with Netmos 9865 Chipset.
    Thanks,
    CP
    Apr 2006
    40
    Never mind, found out the port numbers start at 1, even though the default is 0.
  1. linux emc work with Rorze?
    By bruno meola in forum LinuxCNC (formerly EMC2)
    Last Post: 12-16-2015, 11:01 PM
  2. Only Y works correct X don't work Z works one direction only
    By jdgbadenhorst in forum Hobbycnc (Products)
    Last Post: 06-10-2012, 09:54 PM
  3. X axis works fine but Y axis direction is erratic
    By swampbud1 in forum DIY CNC Router Table Machines
    Last Post: 12-07-2010, 12:28 AM
  4. work linux EMC with Syil SX3 converse?
    By ata in forum LinuxCNC (formerly EMC2)
    Last Post: 04-28-2009, 06:53 PM
  5. Does Xylotex Board Work With Emc (linux)?
    By Hombre Verde in forum Xylotex
    Last Post: 02-01-2007, 07:06 AM
