587,482 active members*
3,385 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Need help going from Fanuc yellow cap to red cap
    Jun 2010
    Hello,
    Looking to replace a Fanuc 10M yellow cap with an Alpha series red cap (may move a rotary 4th to a different machine). I haven't been able to remove the existing motor yet to see the shaft configuration, but was able to get the number off the nameplate. It reads "A06B-0651-B011#0003 (2000M)" - I was told an Alpha 12 would replace it but I don't know the shaft configuration, etc. Does anyone know the Fanuc servo motor nomenclature - I'd like to price a motor before tearing things apart. Thanks.
    Dec 2003
    24220
    The B011 the 0 normally indicates a taper shaft motor.
    I noticed in the 'Other' board you asked about changing the encoder on a redcap, they are keyed and secured by a 5 or 6mm Allen head screw down the centre, they take a bit of a twisting to get it off the taper, but usually very easy.
    They can be replaced on the key either way as they are 8 pole motors so the encoder works in either position.
    Al.
    Albert E.
  1. Yellow Screaming Meemee
    By MrWild in forum Benchtop Machines
    Last Post: 02-06-2010, 05:39 AM
  2. Tuning Fanuc, Yellow Cap DC servo's
    By BodylinezCNC in forum Fanuc
    Last Post: 07-10-2009, 01:25 AM
  3. Yellow cap motor part's
    By Kevin Taylor in forum Fanuc
    Last Post: 11-25-2007, 07:36 PM
  4. Yellow Iridite Pens ???????????
    By CAMCRASH in forum Mass finishing equipment/media/strategies
    Last Post: 06-12-2007, 12:34 PM
  5. Replies: 2
    Last Post: 06-03-2007, 02:21 PM
