603,783 active members*
3,082 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Need help! hawk150 hydraulic pressure too HIGH!!
    Hi, does anyone have any knowledge of the hydraulic system on a hawk lathe? My lathes pressure gauge popped and was leaking, so I replaced it. When I put the new one in and turned on the machine, I had over well over the normal 40 bar pressure, over 800 PSI coming out of the pump! So, I shut the power off, not to destroy the new gauge. Is there an adjustable regulator or something that could cause my problem? Any advice would be appreciated. Thanks!
    I don't have any alarms
    The lathe has the Acromatic 2100 control
    HAWK 150 A2100
    MODEL ERD
    CONTROL DIAGRAM 91203107A
    Mar 2008
    352
    Re: Need help! hawk150 hydraulic pressure too HIGH!!
    Precisionatl,
    See attached file: 91203587A-HAWK-ERD_SYS-HYD-PNEU-COOLANT-Diagrams_1-6.pdf (Page#3 lower left)
    There is adjustment on the pump.
    see: website youtube.com/watch?v=81nzCdIX1aw
    Thank you gwood! That was the fix. Looks like a small speck of metal got stuck in the adjustment valve.
  1. Replies: 10
    Last Post: 11-12-2020, 01:15 AM
  2. Hydraulic pressure switch
    By jbranting in forum Cincinnati CNC
    Last Post: 05-02-2019, 12:54 PM
  3. SL20 Hydraulic pressure alarm???
    By gixxergary in forum Haas Lathes
    Last Post: 11-02-2017, 12:47 AM
  4. Replies: 0
    Last Post: 10-21-2014, 02:49 AM
  5. 1040 Low Hydraulic Pressure
    By pinguS in forum Fanuc
    Last Post: 06-18-2007, 02:53 PM
