603,942 active members*
2,627 visitors online*
Results 1 to 7 of 7
    Mar 2012
    6
    need help in heidenhain itnc 530
    hello everyone!
    i'm working on a hermle c-30 heidenhain control and i would like to set datum automaticly using a program (i would like to be at a certain coordinate and "save" it in the preset table- the values of x,y,z,c,a)
    can anyone help me
    Nov 2008
    69
    Check the SYSREAD (ID270) and then SYSWRITE (ID 503)
    You can read the axis values and then writen them to the PRESET table.
    Fairly easy function. (you need to enter the CODE NUMBET 555343 to get the SYSWRITE functions available. Everything is in the normal user manual.
    Jukka
    Mar 2012
    6
    thank you for answering i found that on the manual , but could you post an example on how i write it in the program i would like to be in a certain position and read and write the coordinates in a different home number how do i do it?
    Nov 2008
    69
    Here is an example:
    0 BEGIN PGM test MM
    1 FN 18: SYSREAD Q1 = ID270 NR1 IDX1 ; Read X-axis position
    2 FN 18: SYSREAD Q2 = ID270 NR1 IDX2 ; Read Y-axis position
    3 FN 17: SYSWRITE ID 503 NR10 IDX1 =+Q1
    4 FN 17: SYSWRITE ID 503 NR10 IDX2 =+Q2
    5 END PGM test MM
    It reads the position of the X- and Y-axes and writes them to PRESET table at line 10.
    Fairly easy, don't you think?
    Jukka
    Mar 2012
    6
    thank you very much you helped me a lot.
    have a nice day
    Nov 2019
    Hello to all. Got a question about programming peck drill cycle. Is it possible to fully retract drill out of a hole if i start to drill in pre-drilled hole? Start is set at-30mm(pilot hole depth) and goes to final depth -100mm.
    Apr 2018
    Re: need help in heidenhain itnc 530
    Quote Originally Posted by Jukka Honkanen View Post
    Here is an example:
    0 BEGIN PGM test MM
    5 END PGM test MM
    Jukka
    Hello Jukka,
    I would like to set the q values that i defined to preset 0. In other words, these values at the beginning of the g-code will automatically take the vise top point + z stock value. What do you think about this code?
    BLK FORM 0.1 Z X-25 Y-25 Z-50
    BLK FORM 0.2 X25 Y25 Z0
    ; STOCK: - LENGHT:50 - WIDE:50 - HEIGHT:50
    Q50 = 0 ; PRESET 0
    Q71 = 50 ; X STOCK
    Q72 = 50 ; Y STOCK
    Q73 = 50 ; Z STOCK
    FN 18: SYSREAD Q1601 = ID507 NRQ50 IDX1 ; This present Vise top X zero coordinate
    FN 18: SYSREAD Q1602 = ID507 NRQ50 IDX2 ; This present Vise top Y zero coordinate
    FN 18: SYSREAD Q1603 = ID507 NRQ50 IDX3 ; This present Vise top Z zero coordinate
    FN 1: Q1604 = Q1603 + Q73 ; Vise Top + Z Stock
    FN 18: SYSREAD Q1604 = ID507 NRQ50 IDX3 ; Record Vise Top + Z Stock to Q1604
    FN 17: SYSWRITE ID 507 NRQ50 IDX1 =+Q1601
    FN 17: SYSWRITE ID 507 NRQ50 IDX2 =+Q1602
    FN 17: SYSWRITE ID 507 NRQ50 IDX3 =+Q1604
    Thanks,
  1. heidenhain itnc 530 postprocessor!!
    By piziotizio in forum PowerMILL
    Last Post: 12-11-2012, 02:20 PM
  2. Heidenhain iTNC 530
    By aslam819 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-19-2012, 08:18 AM
  3. Heidenhain iTNC 530 question
    By Brian Brown in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-19-2010, 10:53 PM
  4. TOS with iTNC 530 HEIDENHAIN
    By SheldonB in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-15-2009, 04:35 AM
  5. Heidenhain iTNC 530
    By Thanya in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-12-2007, 10:33 PM
