603,979 active members*
1,367 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Need Help horizontal part lots of angles
Page 1 of 2 12
Results 1 to 20 of 25
    Aug 2005
    149
    Having trouble programming this part...We're trying to do this part in 2 ops..
    want to do the angles on both sides of this part at the same time from center of rotation of course but I'm having trouble figuring it out...Any help would be appreciated...Everytime I try a pocket path I keep getting boundary does not lie in construction plane...I was hoping I would be able to use a standard path with the solid and be able to use the rotary axis function ,but no such luck..... I'm stuck!
    Thanks...
    Oh by the we're useing version 9..
    Attached Files Attached Files
    Oct 2007
    68
    I just guess you need to create boundary for every rectangle pocket before create toolpath
    Feb 2007
    464
    Shouldn't the part be made so the pockets are in the top plane?
    Stefan Vendin
    Mar 2006
    1013
    That message means that your Cplane/Tplane or your geometry is not square to the axis. You cant cut a tilted pocket. How did you set your CPlane/Tplane? Does it reference the same geometry your trying to cut?
    Mike Mattera
    Tips For Manufacturing Training CD's, DVD's for Mastercam, SolidWorks, Inventor, G-Code Training & More
    http://www.tipsforcadcam.com
    Aug 2005
    149
    I just figured that out....can I rotate the part so the pockets are square and than create the new Cplane/Tplane by selecting those as an entity and than create the tool path...I was just thinking there was an easier way to do this by doing a pocket path and having it rotate on the b axis...
    Mar 2006
    1013
    No, you dont want to rotate the part. When you create the Cplane/Tplane its telling Mastercam where the new toolpath should be (i.e. the angle between). Have you had any training on creating Cplanes/Tplanes of doing 4th axis toolpaths?
    This contains everything you need to do 4th axis work.
    http://www.tipsforcadcam.com/product/TFM-CDRotaryV9
    Mike Mattera
    Aug 2005
    149
    The rotary axis stuff on cylinders is pretty easy...,but I don't want to make a bunch of work offsets for each angle...I shouldn't have too....I want one work offset...there are a total of 22 pockets on this part, that's not practical to have so many work offsets on one part...it's not like their at different angles...I have your cd on the fourth axis stuff and it doesn't cover this....unless I'm missing something..., but what I'm trying to do is complete all the angles in one operation...all front angles and rotate around and finish all the back side angles. What I see the portion that covers multisided toolpaths are blocks with multiple workffsets...I want to make this part with one workoffset from center of the part...It maybe easier to progam with multiple workoffsets...but it seems more of a pain to set-up...I rather have the trickier part be on the programming side and quicker up time on the machine.
    Oct 2007
    145
    I wonder what the best way to do what you are describing is without creating lots of work offsets. I can't look at your file till Monday. Translate-Rotate? Macros? Someone really needs to do an Advanced Rotary and Contour video as a follow up Mike's intro video to help us mortals.
    Sep 2007
    217
    Well Chuy for what it is worth that is the way I would do the part. I have not seen the part, but if I were doing this part I would do it that way. All you need to know is where a reference point is from the center of the tombstone to the mounting surface of the part and put the part in that place in Mastercam. Use one workoffset program all the pockets making them all G54 and done. Not that big of a deal.
    Chuy,
    like Crazy thunder said it is easy to set one offset, but you may have to set the plane wcs not fixture for each pocket to machine each pocket toolplane from the one G54 offset. Unless the toolplanes for each pocket are the same angle then you will only have to set the toolplane once per side.
    Steve
    www.cad2cam.net
    www.cad2cam.net
    Programmer/ Certified Cam Instructor
    Aug 2005
    149
    Ok I figured out the c/plane t/plane part of it, and they are at the same angle, now I notice when I hit the F9 key to dislpay my cross hairs I see that they are at a different position then the wcs....from my main geometry, how can I move them so they all come from the same position? I want every thing relative from the same point..
    Sep 2007
    217
    The best way is take the base C-plane and rotate it to the desired angle then use it to drive the operation. If the 1st angle pocket is 22.675 from the front view then rotate that c-plane about the Z axis 22.675 and now it is at the same X0,Y0,Z0, but just a different A.
    G54 is 0,0,0
    all pocket wcs coordinates should be 0,0,0 they should not different numbers.
    Steve
    www.cad2cam.net
    www.cad2cam.net
    Aug 2005
    149
    Quote Originally Posted by Steve Arteman View Post
    G54 is 0,0,0
    Steve
    www.cad2cam.net
    okay so when you create the new view it automatically associates and shifts the coordinates? and to have it associated with the the original wcs just uncheck that box and make it , 0,0,0?
    Mar 2006
    1013
    Yes. If you have the geometry, you create the Cplane/Tplane using that geo. But your 0,0 doesn't have to be at the intersection of the geo. In the video examples I generally put the 0,0,0 on the face somewhere, but it doesn't have to be. You can put it ay the Abs table center.
    Mike Mattera
    Chuy
    Yes this is what you need, remember where z0 when programming and watch the incremental buttons they like to turn on for no reason in v9.
    Steve
    www.cad2cam.net
    www.cad2cam.net
  17. #17
    Aug 2005
    149
    Okay I believe I got...Looks good when I verify it..thanks for you help guys!
  18. #18
    Aug 2005
    149
    Quote Originally Posted by Mike Mattera View Post
    Mike Mattera
    A little off topic, but something I noticed during backplots of these paths...My toolholders are huge! how can I change the size of them
  19. #19
    Mar 2006
    1013
    You cant. Is this a very small part. or are you in metric?
    Mike Mattera
  20. #20
    Sep 2007
    126
    copy & assign toolpath's
    I have been practicing with this part a few day's now & with the tip's here have been able to figure out how to set my c-planes correctly for each window, front & back. Have been able to chain one pocket to do tool-path's, for just the one pocket. Here's where I'm stumped. I would like to know how to correctly copy & paste my operation's on my one chained pocket & do all the rest without having to select each pocket, one by one & have to repeat the process over & over again , if this is possible. I think this is possible , but I don't know how to copy & paste operation's to multiple X0,Y0,Z0 position's. Thank's, Harold.
Page 1 of 2 12
  1. First CNC, Lots of Questions...
    By michael_giesbre in forum LinuxCNC (formerly EMC2)
    Last Post: 01-24-2022, 12:40 AM
  2. Help Modeling a Part w/ Complex angles
    By nlh in forum Uncategorised CAD Discussion
    Last Post: 09-20-2007, 10:31 PM
  3. Design Xpress - Draft Angles Over 59 Deg.
    Last Post: 08-27-2007, 06:33 PM
  4. slopes and angles
    By massbaster in forum Sharp CNC
    Last Post: 07-12-2007, 04:14 AM
  5. how to mill angles?
    By cowanrg in forum MetalWork Discussion
    Last Post: 05-14-2007, 03:35 PM
