603,335 active members*
3,129 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Need Help identifying the manufacture of this extruded rail
Results 1 to 4 of 4
    Feb 2007
    4550
    I would like to know if there is a source for this extruded rail-track in the U.S..
    or is it home made?
    I know the large one is 8020, I am interested in the one with the round steel bars.
    Thank You
    Jeff Alessi
    May 2008
    Looks like Rexroth LF6S. Carriage appears to be custom.
    Wes
    Dec 2003
    24260
    I used to buy exactly the same item from a company called Item Products, I think Parker took them over and I believe they are marketed under IPS now, http://apps.parker.com/industrialpro...tionalProd.pdf
    The chrome steel rod could be popped into place as needed.
    I am not sure whether they have the same selection, they also had Gantry extrusion with galleys running through for oxy & gas torches etc.
    Failing that, I would send for a Misumi catalogue, they have a large selection of extrusions also.
    Al.
    Albert E.
    Feb 2007
    4550
    A better picture
    Al,
    Thank you for the help, after looking through all the Parker pdf files and no luck finding this.
    This is like finding a needle in the haystack.
    Thanks Again,
    Jeff...
  1. Extruded Aluminum build?
    By KarlHenderson in forum Commercial CNC Wood Routers
    Last Post: 04-25-2008, 04:14 AM
  2. extruded PVC
    By Dar in forum Bridgeport / Hardinge Mills
    Last Post: 09-30-2007, 10:28 PM
  3. mic 6 Al vs. extruded/rolled 6061 t6
    By cyclotron in forum Mechanical Calculations/Engineering Design
    Last Post: 06-29-2007, 06:55 PM
  4. what kind of extruded for cnc frame?
    By blau_schuh in forum DIY CNC Router Table Machines
    Last Post: 10-25-2006, 01:25 AM
  5. Extruded Aluminum
    By DDM in forum DIY CNC Router Table Machines
    Last Post: 03-06-2004, 06:47 PM
