603,981 active members*
2,179 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Need Help! Importing dxf file which is cutter tool assigned, in Masterwork.
Results 1 to 4 of 4
    Sep 2007
    8
    Hi ,
    do you know ?
    How to prepare a dxf file with predefined manufacturing operation to open masterwork?
    How to select values such as cutter tool selection, hole depth in dxf file?
    Is there any guide about this .
    Thanks.
    Mar 2003
    35494
    Re: Need Help! Importing dxf file which is cutter tool assigned, in Masterwork.
    Not familiar with Masterwork, but it's usually done by putting the information in the layer name.
    Something like Route_Z0P5_T3
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Sep 2007
    8
    I found some that specific layer names :
    for drill operations -> BACK , FRONT, LEFT, RIGHT, TOP,
    for saw operation -> SAW
    for milling operation-> TOOL$41_1$L -> I gues 'L' char is tool compansation ileft of the contour.
    But, this not give information about Depth of drilling or milling , or other values.
    What could these parameters be?
    Sep 2007
    8
    Hi finaly I found this table. in source Masterword working directory ( EN - Working with DXF.doc), partly solved the problem .
    Panel Dimetion - PANEL
    Vertical Driling - TOP[$Fn]
    Horizontal Drillings on Left Side - LEFT[$Fn]
    Horizontal Drillings on Front Side -FRONT[$Fn]
    Horizontal Drillings on Right Side - RIGHT[$Fn]
    Horizontal Drillings on Rear Side - REAR[$Fn]
    Indexed Horizontal Drillings - INDEX[$TOOL_NAME][$Fn]
    Saw Blade Cuts - SAW[$Fn][$En]
    Routing Operations - TOOL$TOOL_NAME[$R;$L][$Fn][$En][$Sn]
    Also "4) The information about the Z-axis (panel thickness, working depth on top side and horizontal drilling Z position) is contained into various entities “thickness” parameter."
  1. Importing file help
    By cncmadness in forum Uncategorised CAM Discussion
    Last Post: 08-07-2014, 12:26 PM
  2. Importing IGES file
    By NewToGibbs in forum GibbsCAM
    Last Post: 04-08-2011, 05:10 AM
  3. File importing
    By oknups in forum OneCNC
    Last Post: 03-09-2011, 10:48 PM
  4. importing igs file
    By Cartel, LLC in forum BobCad-Cam
    Last Post: 04-27-2010, 02:39 PM
  5. Problem importing bmp file
    By ChetR in forum Dolphin CAD/CAM
    Last Post: 03-26-2010, 09:03 PM
