603,958 active members*
2,178 visitors online*
IndustryArena Forum > Community Club House > Computer Technology > Computers / Desktops / Networking > Need help installing windows 95 - cdrom wont read
Results 1 to 7 of 7
    Mar 2004
    636
    I formatted my windows 95 machine today. I am going to use it in dos mode to run Turbocnc for my homemade cnc router. I formatted it so that I could do a fresh install of Win95 as I knew I had lots of garbage on this machine that was know longer needed.
    I was able to formate the drive and reboot the system. From dos prompt, I can type in d: and it will give me a d: command prompt like it is recognizing the cd drive. When I type in dir to get a directory of whats on the disk (which is my win95 disk) it says that it cannot read from the drive.
    I thought that it was a bad drive and tried a spare that I had setting around and I got the same thing. Is it possible that I have 2 bad cd drives or am I missing something simple?
    Dan
    Check out what I am working on at www.routerbitz.com!
    Mar 2003
    6855
    Their may not be any drivers loaded that support your CD drive, do you have a install floppy disk? Did you create a dos partition and make it active?
    Dec 2003
    24260
    Do you want to bother with windows if you just need dos, Paul posted the link to the MSDOS 7.1 a while ago http://newdos.yginfo.net/msdos71/index.htm
    It has a flash screen on boot up and allows long file names as well as a few utilities.
    You still have to high level format the HD as well as set a partition as has been stated.
    Al
    Albert E.
    Apr 2004
    439
    try a win98 se bootdisk it has better cdrom drivers http://www.bootdisk.com/bootdisk.htm
    Mar 2004
    636
    Do I need Windows?
    Well I guess I really don't know. I am using a Windows XP machine in the house with TurboCad and will be using TurboCNC on my Garage machine to run the CNC router.
    What I need then is:
    1. Some type of converter software to turn the cad drawings into G code. Any recommendations here? Should this be on the XP machine or Dos Machine?
    2. A way to tranfer the files from the Xp Machine in the house to the dos machine in the shop. Will simple files fit on a floppy disk or will the file size be to big? That is the main reason why I wanted to get the cd rom working was to transfer files.
    Thanks all
    Mar 2003
    35494
    Quote Originally Posted by Hack
    Dan
    I'm going to guess that the win 95 boot disk creates a RAM disk, which your seeing as D: Your cd probably isn't being seen due to drivers not being loaded.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Apr 2003
    1876
    Go to bootdisk and look for a set of dos utils that will allow you too boot in dos with CD Rom support.
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
  1. cnc control software for windows xp
    By Ralph Burge in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-29-2008, 01:21 AM
  2. punch or read with fanuc
    By formulaz in forum G-Code Programing
    Last Post: 01-27-2005, 04:10 AM
  3. Windows XP or Windows 2000 better with Mach2
    By Beezer in forum Mach Software (ArtSoft software)
    Last Post: 10-18-2004, 04:08 PM
