There are 2 24VDC power supplies in this machine. One power the control power supply, the other the relays, etc. they are in the right side cabinet, top, center. They do go out quite often. Check power in, transformers for correct taps, etc. as well.
The blanks are typically machine specific parameters. Backlash, travel limits to each side of the home switch etc.
All these machines came with a red box with the manuals and a hard copy of the machine parameters.
You can see if the prior owner was smart enough to have downloaded the parameters to his PC and if he could provide a copy.
George
