587,768 active members*
3,261 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Lathes > Need help for make threading cnc programe
Results 1 to 7 of 7
    Jan 2009
    117
    Unhappy Need help for make threading cnc programe
    How can i write this programe to run Hass CNC lathe M/c
    Part outer Diameter 42.5mm
    Length: 100mm
    Pitch 80mm
    No of starts: 45
    Left and Right hand thread
    Depth: 1mmAttachment 368384
    Jul 2016
    660
    Re: Need help for make threading cnc programe
    Actually you dont need to write a CAM program for that, just buy a knurling tool for lathe then voila it can finish the work in seconds, not several minutes...
    Jan 2009
    117
    if it is possible to depth 1mm by nurling tool...
    Nov 2006
    490
    It's technically possible to cut a knurl with single-point passes, but there are many limitations to it. Like he said above, it's VERY slow since the cutting tool will run into feedrate limits. You also need to have clearance on either side of the knurled area (like 5mm, depending on the RPM)
    In the past I tried to make a knurl using a thread tool (we did not have enough room in the turret for any other tools) but the program needed to be tweaked over and over. I was never successful with it (you could see the knurl marks change shape because of the machine accelerating and decelerating)
    So I would agree, a knurl tool is easier by far! You'll need to purchase the correct knurling wheel to create a "coarse" pattern.
    Jul 2016
    660
    I can give him a programmed g-code for the one he actually wants but yes it's painfully slow, im guessing 15 minutes per work, unlike a knurling tool 10 seconds good to go hehe
    Sent from my SM-J120H using Tapatalk
    Jan 2009
    117
    Quote Originally Posted by KH0UJ View Post
    Please brother give me programe, just i like to test that programe.
    thanks
    Jan 2009
    117
    Quote Originally Posted by Ydna View Post
    thanks for your information. above mention details, how can i choose knurling tool? give me some details.
  1. programe pattern
    By fsa in forum Fanuc
    Last Post: 04-16-2017, 06:00 PM
  2. NEED ATC PROGRAME FOR CINCINNATI
    By m.amir in forum Cincinnati CNC
    Last Post: 11-28-2013, 08:08 PM
  3. 4th Axis Programe
    By splicer in forum Fanuc
    Last Post: 12-27-2012, 06:49 AM
  4. arcs in threading programe
    By bala955 in forum Surfcam
    Last Post: 02-17-2010, 06:34 PM
  5. Replies: 2
    Last Post: 04-08-2009, 11:27 PM
