588,039 active members*
3,783 visitors online*
    Mar 2011
    Need help Mazak Tap Cycle Error
    Hi, I new with mazatrol programming. I programmed a 1/4-20UN tapping cycle on a milling centre and the spotting, drilling cyles works fine but when it comes to the tap I get this error:
    952 NO SYNCHRONIZED TAP OPTION (REWORK-C, 4, 3)
    Can someone help me on that one. I know it needs to index itself before tapping but I don't know how to do it.
    Mar 2005
    988
    According the the alarm, you don't have synchronized tapping option... Need the option.
    Or, you should be able to go with a floating tap set up. On the Tool Data, you need to change the tap type to floating and put together a floating set up.
    It's just a part..... cutter still goes round and round....
    Mar 2011
    Thanks a lot, it really helped me. To confirm what you were saying, I went in the parameters of the machine and indeed the rigid tapping option wasn't purchased on the machine.
  1. Use cycle simulation time error
    By pinguS in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 04-14-2011, 07:53 AM
  2. Mazak G81 Drill cycle
    By ggborgen in forum G-Code Programing
    Last Post: 03-01-2010, 09:17 PM
  3. Mori MV-JR Power off during ATC cycle error
    By dddamian in forum Fanuc
    Last Post: 09-23-2009, 03:17 AM
  4. Mazak M32 - G84 Tapping Cycle Broken?
    By CimUser2000 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-13-2009, 01:48 PM
  5. error in drill cycle
    By TPPJR in forum OneCNC
    Last Post: 01-28-2006, 07:21 PM
