Ok, what I'm doing is mounting hardwood blanks to my table for cutting out gun grips.
My first test piece I used contact cement to secure it to the table. I was cutting MDF since it was just a test and it seemed to work fine.
Tonight I did the same only tried it on a piece of mesquite. When the router was moving away from the direction of the spindle, everything was fine. However, as soon as it started moving in the direction of the spindle, it did just as you would expect if you tried the same thing on a shaper table. It broke the contact cement bond with almost no difficulty and threw the blank across the room.
Fortunately, it was just a scrap piece of mesquite from the wood shop floor, so no great loss, but still... how can I securely mount my blanks?
I can't really use a hold down system unless I use much wider and/or longer pieces of hardwood and that'll result in alot of waste.
I've tried glue and paper before, on my old pantograph, but that was really messy. And I had to wait awhile for the glue to set before I could cut.
So what else can I do? Just when I get the machine working really well, I run into yet another big hurdle.
Please help.
