587,952 active members*
3,675 visitors online*
    May 2014
    20
    NEED HELP - MV-40B SPINDLE PROBLEMS
    Hello, I need help...Lots of it.
    A little about our machine first:
    - MORI SEIKI MV-40B 1989
    - FANUC 0-M Controller (model: A02B-0098-B511)
    And now its problems:
    - when it starts up if it gets past the 408 alarm duing a cycle 409 will show up which cripples the machine. if 408 shows up on start up it does not get past there.
    - Alarm 408 SERVO ALARM : (SERIAL NOT RDY) has been showing on occasion over the last couple of years, however over the last week it has become very frequent ( daily/hourly) and eventuly it would come up during a cycle.
    - On the AC SPINDLE SERVO UNIT PCB the alarm on the display shows AL-19 which when we did some research one source said if check pin IU was above 0.1 of a Volt the board shoudl be replaced, On checking it, it was 0.43 of a Volt.
    - We paid FANUC to replace the board with a new one ($4300) whick they siad it was about %80 likely to fix the problem. that was yesterday.
    - today i started it up and began running a program for a urgent job and it has started all over again.
    Not sure if any of that makes sense or if any of you have had the same issuse but if you can help i would be over the moon.
    Please let me know,
    Nathan Noakes.
    Aug 2019
    27
    Quote Originally Posted by Buchananesq View Post
    Please let me know,
    Nathan Noakes.
    Can you help me please. I was change my control of my MV-40B because my NC module has broken. I has backup parameter and some other settings. But unfortunately i forgot to backup the ladder program. Can you send me the ladder please. Mori Seiki MV-40B MSC-518. Please email me.
    Bagas
    [email protected]
  1. Replies: 18
    Last Post: 11-07-2020, 01:48 PM
  2. Spindle problems . What is the runout on your spindle?
    By eltejano in forum Tormach Personal CNC Mill
    Last Post: 04-05-2017, 06:56 AM
  3. more spindle problems
    By groundhog719 in forum Syil Products
    Last Post: 04-26-2011, 05:39 AM
  4. Spindle ON (M03/M04) problems
    By garboui in forum LinuxCNC (formerly EMC2)
    Last Post: 01-26-2010, 11:24 PM
  5. spindle problems
    By IeatSteel in forum Bridgeport / Hardinge Mills
    Last Post: 06-13-2006, 07:23 PM
