Torque does in fact = current. With a permanent magnet motor the speed is regulated by the back EMF, which once it reaches roughly = the applied voltage, speed increase will cease.Originally Posted by jdelaney44
If the motor is loaded at all then the speed will drop and so will the back EMF allowing an increase in current.
There are ways of increasing the voltage, therefore current, by either a linear amplifier (0v to max DC), or by the increase in energy by PWM signal.
Obviously if max voltage or PWM was applied at stall then you would burn the motor out if some form of current limit was not applied.
Al.
