603,899 active members*
3,237 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > Want To Buy...Need help! > need help to pick cnc machine for my needs
Results 1 to 6 of 6
    Nov 2015
    i'm wanting to start a side business making wooden objects and selling them, i need to cut out parts of pine 6"x1"x3/4" deep for example and an inner triangle cutout from another piece of wood, until now I've been thinking of buying a sliding mitre saw, a scroll saw, a drill press, etc.. but yesterday was thinking I could do most of the wood cutting with a cnc machine and it would be safer than a scroll saw.. my question is, which wood cutting cnc machine do you suggest that is ready to go (pre-assembled, not a kit) for 1000$ or less?
    forgot to mention my biggest piece of wood for this project is the base where I will glue the other pieces onto, base size is 6"x9"x3/4" deep
    Jul 2014
    147
    Re: need help to pick cnc machine for my needs
    Hi Sir,
    According to your description, you at least need to pay $6000 for your project.
    Best&Rgds
    Apple
    Apr 2004
    5951
    It sounds like you'd be better off cutting these parts with a saw. Definitely those pine pieces and the base would be much faster to make with a table saw. A sliding miter saw might be best for the triangles, unless you're talking about cutting a triangle out of the inside of a piece of wood - that would be something you might use a CNC router for, although if that's all you're doing a regular plunge router used with a template would work just as well - or maybe better than the sub-$1000 CNC machines you're considering. For $1000, you should be able to get a fairly decent table saw, a plunge router, and a drill press, maybe a scroll saw as well.
    Andrew Werby
    Website
    Mar 2003
    35494
    There are very few machines available in your price range, except for maybe the chinese ones on Ebay. And with those, don't be surprised if you need to replace the electronics when they go up in smoke.
    And don't forget to add in the cost of software.
    A scroll saw is probably the safest woodworking tool you can use.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Mar 2012
    109
    The only thing I can think of here would be a Shapeoko or similar.
    Dec 2015
    3
    Can you tell the specific requirements of CNC machine?
  1. Kflop DIY Pick and Place machine
    By bri999 in forum Dynomotion/Kflop/Kanalog
    Last Post: 08-17-2015, 10:47 PM
  2. someone help me pick out a nice starter machine!!
    By bobsmyuncle in forum Waterjet General Topics
    Last Post: 07-22-2012, 11:12 PM
  3. Need help to pick a CNC machine for aluminum
    By k24z3 in forum Uncategorised MetalWorking Machines
    Last Post: 12-28-2010, 03:09 AM
  4. pick & place machine
    By gombault in forum LinuxCNC (formerly EMC2)
    Last Post: 09-19-2009, 07:19 AM
  5. Which plasma machine do I pick?
    By HMD in forum Waterjet General Topics
    Last Post: 10-10-2007, 08:35 PM
