Originally Posted by
HASH-MACH96
Afternoon guys, roughly 2-3 months ago my original post got corrupted due to computer error so I wrote new posts for all the NC mills at the shop using edgecams code wizard and a little manual input. Now everythings been fine except for one problem, whenever I use several hole cycles in one sequence the first cycle will have all the values needed but the cycles after that don't contain the z-value specified.
For example:
T01 M06 (10MM DRILL);
G0 G90 G54 Y0.0 X0.0 S473 M03;
G43 Z5.0 H01 M08;
G83 G98 X0.0 Y0.0 Z-5.0 Q2.5 R2.0 F100.0;
G80;
G0 Z150.0;
G83 G98 X50.0 Y0.0 Q2.5 R2.0 F100.0; <---Missing z-value
G80;
G0 Z150.0;
G91 G28 Z0.0 Y0.0;
...and this happens many a time when two hole cycles are under one tool for different depths as shown above, yet the next tools cycle will be fine then the tool after that has the same problem and so forth, there's no clear pattern to it, seems random but obviously that's not the case.
I'm not looking for an alternative but a solution to whats wrong in the post.
I've had this problem before using a 1983 Dahlih 1st series fanuc post but it wasn't as frequent and I'd have to use atleast 4 hole cycles before I have one cycle with the z-value missing.
The post modified to produce my current posts is from a 3-axis Fanuc Robo-Drill 31i control closed bed mill.
The mills I made posts for are the following:
SMTCL oi-fanuc control, Dahlih (1983) 1st series fanuc control and a Bemato oi-fanuc control
Please if anyone uses Edgecam 2014 R2 and has written posts before using the code wizard, your advice would be greatly appreciated
