I have just learned CNC programming, Okuma codes, and I find it difficult. I could use some help. I have linked my "assignment", I need help to get it finished. I have a "task" to make 4 pieces to a bed. These 4 ends are steel, and will be produced in a Okuma LB9 machine. This is what i've got of information :
Aditional info :
* I have 4 x stock, length 80mm, diameter 45mm
* Material is steel
* Coarse cut :
*** Spindle speed 200 m/min
*** T050505
*** Nose radius 0,8 mm
*** Thread angle 60 degrees
*** Thread pitch 75 degrees
* Fine cut :
*** Spindle speed 300 m/min
*** T010101
*** Nose radius 0,4 mm
*** Thread angle 55 degrees
*** Thread pitch 93 degrees
*** Allowed nose radius compensation on the last fine cut
* Thred Cutting M42x3, look af pix
*** Spindle speed max 75 m/min
*** T040404
*** Profile angle 60 degrees
* Largest cut area is 0,9 mm^2
* Max feed-rate 0,3 mm
* Max cutting depth 3,5 mm
* Maximum spindle speed 4500 rpm
I hope someone can help me, cause this is kind of a new area for me
E.
Privat e-mail : [email protected]
