603,940 active members*
2,350 visitors online*
Results 1 to 9 of 9
    May 2018
    17
    Need help with proximity switch setup
    Mx4660, uc100. I’m trying to setup proximity switches, I guess I’m just retarded. I go to the axis setup page, put in the pin #, hit enter, apply settings and the entry goes back to 0. Any help would be much appreciated
    Re: Need help with proximity switch setup
    Make sure you have a licensed version of UCCNC and you are not working in DEMO mode. Test inputs, to confirm you have communication OK.
    Arturo Duncan
    https://cnc4pc.com
    May 2018
    17
    Quote Originally Posted by arturod View Post
    Arturo Duncan
    https://cnc4pc.com
    Green and blue lights on, jog working fine
    Mar 2003
    35494
    The port and pin number you are using is probably an output pin.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    May 2018
    17
    I guess I m really lost. The PIN number I’m trying to use is the PIN number on the 4660
    Mar 2003
    35494
    What port and pin numbers are you entering?
    Gerry
    Feb 2012
    150
    Is the demo version limited for controlling outputs?
    Sent from my SM-T813 using Tapatalk
    Apr 2014
    59
    You also have to select port 1 when setting a pin. Input pins are 10, 11, 12, 13 and 15. The UCCNC zeros the port and pin if you enter an invalid port/pin pair, or try to assign an input pin to output function or vice versa.
    Apr 2014
    59
    Quote Originally Posted by healinhand View Post
    I checked the MX4660 manual. It sees the world form inside. When you connect something to its input, you have to check the DB25 (CN1) table to find that which output connects to your input. So, you connect output pins to inputs and vice versa... (E.g.: if you connect your proximity sensor to input 1 on MX4660 then its output is pin 10 on CN1, so in UCCNC you have to set port 1 pin 10.)
  1. NPN home proximity switch
    By Upnorth4 in forum Mach Software (ArtSoft software)
    Last Post: 08-20-2018, 12:14 PM
  2. NPN Proximity Switch
    By kolias in forum CNC Machine Related Electronics
    Last Post: 08-05-2016, 07:04 PM
  3. old 3 wire proximity switch to new 2 wire proximity switch
    By RH_Machine in forum Mori Seiki lathes
    Last Post: 03-19-2015, 10:25 PM
  4. Limit switch replacement with proximity switch?
    By Normsthename in forum Bending, Forging, Extrusion...
    Last Post: 07-11-2009, 04:38 PM
  5. PROXIMITY SWITCH ?
    By Chappyd in forum Hyundai Kia
    Last Post: 01-15-2009, 02:25 AM
