587,997 active members*
1,487 visitors online*
IndustryArena Forum > Community Club House > NEED HELP FOR RTA PAVIA SDC 05 DRIVES TIMING
Results 1 to 11 of 11
    May 2011
    Can anybody help me where to get step time, step space, direction hold & direction setup for RTA PAVIA SDC 05 motor drives? help me plzzzz
    May 2008
    142
    Hi
    You will find all the info you need on this post.
    http://www.cnczone.com/forums/calibr..._32-65vdc.html
    May 2011
    Question
    Quote Originally Posted by mkc2 View Post
    Hi
    Thanks mkc2,
    in the post, you said that you use sherline 1/2 pulse mode setting. so,
    step time = 1000 ns
    step space = 6000 ns
    direction hold = 24000 ns
    direction setup = 24000 ns
    refer to this link
    EMC Documentation Wiki: Stepper Drive Timing
    is that true?
    May 2008
    142
    Sorry but I dont understand these timing settings, I dont see these any where on my setup.
    I dont use the same drives as you ,but they would be similar to your setup.
    My drives are the GMD-02 RTA.
    May 2011
    do you use emc2 or mach3?
    May 2008
    142
    I use Mach3.
    May 2011
    I use Mach3.
    oic..i asking this for latency test in emc2..
    i'm not very familiar with mach3..
    is that in mach3 dont use step time, step space, direction hold & direction setup to setup? hmmm im confuse now
    May 2008
    142
    You can download mach3 and have a look at the settings, it will give you the full version but only allow 500 Gcode lines untill you buy the licence key.
    May 2011
    ok i will try mach 3...
    can u share to me mach3 settings for your GMD-02 RTA drives?
    i need some guide to refer bcoz i'm not familiar with this sofware...:cheers:
    May 2008
    142
    Some settings to get you started in mach3.
    Attached Files Attached Files
    May 2011
    thank you so much :wee:
  1. RTA Pavia SBC04 Stepper Motor Controller
    By jablakeslee in forum Stepper Motors / Drives
    Last Post: 01-22-2010, 04:53 PM
  2. RTA PAVIA SDC 05 32-65VDC Stepper Driver Wiring Connection Diagram
    By guy2b1 in forum Calibration / Measurement
    Last Post: 12-18-2009, 02:31 PM
  3. RTA Pavia stepper drivers - Anyone with experience?
    By TerraWombat in forum CNC Machine Related Electronics
    Last Post: 07-26-2009, 09:20 AM
  4. Plasma Table Timing Belt Linear Drives
    By Richard Honey in forum Waterjet General Topics
    Last Post: 10-04-2007, 08:47 PM
  5. Replies: 1
    Last Post: 07-24-2005, 12:31 AM
