603,870 active members*
2,959 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Need help selecting a new transformer
    Sep 2004
    235
    Hi
    I need to change my z axis stepper to a larger motor. It seems
    I`m loosing steps on the Z axis. I have a secondary power supply
    in place that has a max amp rating of 4 amps. It seems now the
    supply is too small for the homeshopcnc stepper I`d like to use.
    So I need a new transformer for the z and a potential 4th axis.
    I don`t have room in the enclosure for a toridal transformer so
    I need a recommendation for a standard square transformer and
    also a recommended voltage and amp rating. I`m hoping someone might
    have a source for this transformer. I looked at Mouser and Digikey
    but a 10 amp 48 volt transformer seems hard to find. I use Gechos
    on all the axes.
    Regards Barry
    Motor
    http://www.homeshopcnc.com/page3.html
    Holding torque-Nm (oz/in) +/- 10%...4.5
    Rated voltage.....2.3
    Rated current per phase (amps DC)...5.5
    Resistance (Ohms) +/- 10%.....0.42
    Induction (mH) +/- 20% typical.....3.5.
    Motor length (mm)....80
    Nov 2005
    938
    Hi Barry
    Check Phil's page http://pminmo.com He has a 24V, 10A tranny specked out. It's not the 48V you were asking for.
    Steven
    Dec 2005
    16
    Quote Originally Posted by sdantonio
    Hi Barry
    Steven
    Take 2 transformer from http://pminmo.com and you can make
    the 48 Volt 10A you need.
