Hi Louie, Yeah I understand all that, I was just verifying what you were suggesting...
[quote=louieatienza;974508]It's not easy to obtain a laser that will engrave wood. You probably need about 25-30 watts; good luck finding someone to sell you one, and they're not cheap! Plus you'd have to set up the optics (lenses, mirrors) and need to move at very high speeds and acceleration. [QUOTE]
I wasn't serious....sorry
[QUOTE=louieatienza;974508]You can pretty much use any finish over shellac. Shellac comes on different "tints." You could spray oil based poly or lacquer over linseed oil, but if spraying lacquer over linseed oil you may run into adhesion problems if you wait too long.[QUOTE]
This is where some experimentation is needed (without much of a time window to do it).. But I plan to start playing with it all this weekend..
We'll see.. The mask I bought is supposed to be intended for this purpose (CNC Machining).. It was recommended by others in the Vectric Forums.. Hope it works, because it certainly wasn't cheap..
:cheers:
