587,299 active members*
3,595 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > DynaCNC > Need help with servo alarm on dyna DL3300 lathe
    Nov 2007
    13
    hello,
    On start up machine showed a servo alarm 006B S , I know is a spindle alarm
    but don't know how to fix it. It also says ATC not initialized. Anyone knows
    what is this about? I would appreciate some hints, Thanks.
    Oct 2005
    672
    Which control do you have? L3? 520?
    ATC initialization is done after performing the zero return of the X & Z axes. Turn the Mode Select switch to T, go to the TOOL/PARAM screen. Use the soft keys at the bottom to get to the PLC-SW menu. Then locate the ATC Initial parameter, enter the number at the bottom and press enter. Make sure the turret is clear because it will try to spin to tool #1.
  1. Servo alarm 414 Harrison ge fanuc Alpha 400 lathe
    By davide.castro in forum Fanuc
    Last Post: 08-25-2013, 07:01 PM
  2. Replies: 6
    Last Post: 04-29-2011, 11:20 PM
  3. DYNA DL3300 CNC LATHE, need help!
    By tac in forum DynaCNC
    Last Post: 02-27-2009, 02:45 AM
  4. DYNA 3000H lathe
    By PapaJohn in forum Benchtop Machines
    Last Post: 10-28-2008, 12:01 AM
  5. Retrofit a Dyna 3000 Lathe
    By starlight in forum Open Source CNC Machine Designs
    Last Post: 05-07-2008, 12:45 AM
