587,311 active members*
3,586 visitors online*
Results 1 to 7 of 7
    May 2011
    29
    NEED HELP SETTING PLANE ON ANGLE
    I AM TRYNG TO SET A PLANE ON A BLOCK THAT IS KICKED ON A ANGLE. GOT A BUNCH TO DO WITH DIFFERENT ANGLES. HAVE A MAZAK 510C. TRYING TO PROBE THE BLOCK, BUT CAN'T FIGURE IT OUT. SEEN IT DONE ABOUT 8 YEARS AGO. ANY HELP?
    THANKS
    Feb 2007
    198
    CNC Coordinate Rotation (G68) - a knol by Steve Paffel
    Would G68 be a help for you?
    -jim
    May 2011
    29
    THE BLOCKS ARE WELD ON NOW THE BOSS WANTS TO PICK UP EVER BLOCK AND CUT WELD SMOOTH. JUST STAYING OFF THE BLOCK .001 TO .003. THEY HAVE .05 TOLARANCE ON LOCATION. SO THEY ARE ALL OVER THE PLACE.
    Mar 2005
    988
    Are you using probe software like Inspection Plus or something else?
    also, are you on a rotary table or just trying to machine at that plane angle or just trying to straighten the plane out normal the machine axis?
    It's just a part..... cutter still goes round and round....
    May 2011
    29
    WE DONT HAVE INSPECTION PLUS.
    I TALKED WITH A GUY FROM MAZAK THIS MORNING AND HE SAID WE COULD USE XYthCNR PICK UP. HE WAS GOING TO PLAY WITH IT ON THERE MACHINE TO FIGURE OUT HOW TO DO IT. STILL WAITING TO HERE BACK
    Jul 2003
    1220
    Hi. Can you post a rough wire-frame sketch of a block giving some angles. This may help us to see your problem.
    May 2011
    29
    got it to work. not the way i would like to do it but gets the job done.
    having to do all in mazatrol and using letter offset insteed of g54,g55,or so on.
  1. How setting tools and setting offset
    By John246 in forum Sharp CNC
    Last Post: 04-09-2016, 08:31 PM
  2. Howto: Set plane on angle.
    By Deviant in forum Solidworks
    Last Post: 04-28-2005, 06:06 PM
  3. construction plane and tool plane
    By nervis1 in forum Mastercam
    Last Post: 11-05-2004, 06:53 AM
  4. My New plane
    By cncadmin in forum Community Club House
    Last Post: 11-25-2003, 06:25 PM
  5. cycles initial plane/retract plane
    By HuFlungDung in forum OneCNC
    Last Post: 06-27-2003, 01:02 AM
