603,942 active members*
3,295 visitors online*
    Dec 2008
    Need help sizing servo motors
    I need help sizing two servo motors for my router table. The table will be mounted to an A-frame at 10 - 15 deg. Table Dimension - 246" x 86"
    In the short direction (z-axis) i will be using a Nook linear actuator (EGK80) to move a 60lb cnc router/spindle at a rate of 200ipm.
    In the long direction, i'm using thk linear rails with gear racks to move the grantry. Estimated weight of the gantry with motors/rails/router is about 350 lbs. I want to move this at 200ipm.
    i'm pretty new to all this cnc stuff. i've been searching this forum and reading but everything is still greek to me. Any help is appreciated. thanks
    Mar 2007
    137
    with the info given, I vote for a 29 in.lb dc servo geared at 7 turns per inch for the short, and a 40 in.lb. dc servo at 7 turns per inch for the 350 pounder.
  1. Sizing stepper motors
    By Marwell in forum Stepper Motors / Drives
    Last Post: 09-19-2007, 05:34 AM
  2. Servo Drive Sizing
    By GEMorris in forum Servo Motors / Drives
    Last Post: 07-20-2006, 01:00 AM
  3. Help with Sizing a servo drive.
    By Fabric8r in forum CNC Machine Related Electronics
    Last Post: 10-28-2005, 07:56 AM
  4. sizing of servos or stepper motors
    By BarneyW in forum Servo Motors / Drives
    Last Post: 04-25-2005, 07:14 AM
