603,945 active members*
4,021 visitors online*
    Jul 2003
    53
    Question Need help with subroutine
    Hello,
    Could someone please post an example of a subroutine that would allow the same tool path(s) to be used at 10 different locations, using the same workshift? I'm using a Mitsubishi Meldas controller, and I would appreciate some help! Thank You for your time.
    Sep 2004
    28
    Heres how we do it.
    Hi 2_jammer:
    Is this is what you are looking for?
    this program should make 3-100X100 squares
    the first one starting at x50 y50 z 10
    the second at x250 y 50 z10
    and a third at x450 y50 z10
    I hope it helps
    Jim
    Attached Files Attached Files
  1. Need help with a subroutine formulae...
    By Darc in forum G-Code Programing
    Last Post: 01-10-2006, 12:05 AM
  2. Replies: 11
    Last Post: 10-09-2005, 05:45 AM
  3. Repeat g-code with y offset
    By tpaulson in forum G-Code Programing
    Last Post: 11-29-2004, 08:36 PM
  4. Lathe programing help
    By smitty in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-23-2003, 04:39 PM
