588,585 active members*
14,007 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Need Help With Tool Change Problem
    Sep 2006
    31
    Hello All,
    I need some help with a tool change problem. While in the middle of a tool change an enclosure door opened and the safety interlock shut the machine down. The MT is an AMERI-SEIKI Cyclone1 with an O-MD control. the tool changer arm engaged both tools, dropped to the clearance position, started to rotate and halfway through its rotation the door opened. I was able to remove the tools but cannot get the arm reoriented or in its initial position. I have limited documentation from the MTB who will provide no help. I've tried all MDI options and power off / on to no avail. Can anyone help?
    Thanks.
    Dennis
    Sep 2006
    31
    Hi There,
    Please disregard the previous request. We have bigger troubles than the tool changer.
  1. VF3 tool change problem
    By cata1351 in forum Haas Mills
    Last Post: 10-19-2007, 12:11 AM
  2. Problem in tool change
    By ahmedsamy_81 in forum CNC Machining Centers
    Last Post: 03-28-2007, 09:35 PM
  3. Problem in Tool change
    By ahmedsamy_81 in forum G-Code Programing
    Last Post: 02-14-2007, 04:02 AM
  4. Problem in tool change
    By ahmedsamy_81 in forum Uncategorised MetalWorking Machines
    Last Post: 11-06-2005, 11:14 PM
  5. Replies: 6
    Last Post: 08-24-2005, 08:47 PM
