547,590 active members*
2,515 visitors online*
Results 1 to 4 of 4
    Question need help tunning step motors
    hi i am a complete newbie at setting up a cnc. i have ran one for work for the past 6 years but never set up a new one.
    what i have is a home made plasma table 5x5.
    i run the mach 3 software
    the problem i have is my x and y axis step motors run very jerky and make grinding noises and not even close distance its supposed to.
    all three motors are nema 23
    x and y are belt driven to i believe a 3 to 1 reduction i have not counted the teeth yet.
    any help would be appreciated
    Apr 2004
    5393
    Re: need help tunning step motors
    Could you share some more details about your setup, like what drives you're using, what settings you've chosen, what the specific motors are you're trying to drive, what is transmitting the power to them (eg: screws, rack and pinion) what you're using for slides, and why you decided to use a 3 to 1 reduction? Does this always happen, or just when your plasma cutter is on?
    Andrew Werby
    Website
    Apr 2005
    283
    For the beginning, enter motor tuning and lower velocity and acceleration and start from there.
    On Mach forum you can find a ton of documentation.
    Make no mistake between my personality and my attitude.
    My personality is who I am. My attitude depends on who you are.
    Jul 2017
    272
    If u are using parallel port make sure your communication speed is good by using "driver test" in ur mach3 folder
    Since u are making a home made cnc it could be lots of diff things causing this...the key is ruling things out
    Do motors grind when not connected to axis?
    Make sure wiring to controller board is properly seated and tight
  1. Step Syn Motors
    By hpapilot in forum Stepper Motors / Drives
    Last Post: 06-04-2015, 02:25 AM
  2. 3 Axis, 4 motors - any step by step config?
    By nicubila in forum LinuxCNC (formerly EMC2)
    Last Post: 12-30-2012, 12:27 PM
  3. Step motors moves 1 step only
    By alecu7 in forum Hobbycnc (Products)
    Last Post: 10-16-2008, 06:18 PM
  4. I got the step motors so what's next
    By rbocaz in forum General Waterjet
    Last Post: 08-14-2006, 05:04 PM
  5. Before buy the Step Motors.
    By samsagaz in forum Stepper Motors / Drives
    Last Post: 03-29-2005, 12:50 AM
