587,999 active members*
1,820 visitors online*
Results 1 to 8 of 8
    Jan 2014
    4
    Need help urgently
    I have a jq 1290 laser cutter and having problems cutting the problem is when you cut on the far right side of machine it doesn't cut right through the plywood 3mm thickness but when you you cut on left side of the machine it flys through the plywood have even slowed speed down and power is up to 95% of 100watt tube any idea would be great thanks
    Jan 2008
    940
    Have you checked the alignment of the mirrors. THe laser should hit the center of all the mirrors at any point on the machine.
    Dec 2007
    98
    May I add, there are some great videos on YouTube about aligning laser mirrors.
    Quote Originally Posted by fixtureman1 View Post
    Jun 2013
    45
    Keith, As said by the others, check your mirror alignment. Also check that your laser bed is level at all points, you might find that your bed dips down or is higher in several places which will take it out of focus. I have had to made a "sub-bed" to go under the honeycomb bed to correct the level on mine and it still isn't perfect but it works better.
    Jan 2014
    4
    Yes alignment of mirrors is perfect whatI did find was as laser head is on far right the beam is not really a dot on the paper you do when setting mirrors up but is when its on left side of machine its as thou the beam gets weaker the further it gets from the second mirror
    Jan 2008
    940
    Are your mirrors clean or scratched.
    Jan 2014
    4
    There clean but when you cut on left hand side they fog up after an hours use so need cleaning all the time I have another laser made by piranha and that just keeps going fine for over a week before it needs its optics cleaning
    Dec 2013
    15
    Is this occurring on the same y-axis position? Otherwise, the front left power and the back left power are the same?
  1. Parameters needed urgently
    By m4martin in forum Bridgeport / Hardinge Mills
    Last Post: 11-24-2014, 06:19 AM
  2. Urgently Need QT25 T2 paramters!!
    By In2processAU in forum Uncategorised MetalWorking Machines
    Last Post: 08-30-2012, 07:15 PM
  3. Urgently need a Controller
    By tt-boy in forum Stepper Motors / Drives
    Last Post: 09-20-2009, 01:18 AM
  4. Need Help Urgently
    By makinoman in forum Mastercam
    Last Post: 07-25-2007, 07:11 PM
  5. Urgently need some information...
    By Dave's_Not_Here in forum MetalWork Discussion
    Last Post: 03-21-2007, 06:31 PM
