603,979 active members*
2,341 visitors online*
IndustryArena Forum > CAM Software > EdgeCam > Need help using G83 peck drill cycle
Results 1 to 9 of 9
    Nov 2010
    65
    Hi Folks, I hope some of you can help me with this problem I'm having.
    I'm trying to drill a 6 mm (63 mm deep, using a solid carbide drill) hole into a piece of steel that has been hardened to 60 HRC. My problem is the drills are breaking randomly, and my guess is that when using the G83 cycle the drill moves into the hole in rapid feed, which means if a little chip is stuck, on either the edge of the hole or on the drill itself, it will get dragged into the hole at rapid feed and thus breaking the drill.
    I have tried to set the safe distance to 63mm meaning it would always start feeding above the hole, but my cam software tells me it would take several days to complete one hole (which I'm not really interested in :nono. I was adviced to run at 350 RPM and with a feed of 2 mm/min and pecks at ½ mm.
    Any suggestions on how to stop breaking drills?
    //Lene Madsen
    Oct 2010
    21
    hi I don' t know what kind of control do you use but if this is mazak you can use G73
    N34 X30. Y674.5
    N35 G43 G0 Z5. H25
    N36 G73 X30. Y674.5 R5. Z-33.543 Q2. K17. D4.F440.
    Jun 2008
    125
    Hi guys,
    See my attachments.
    Sounds like you need to be using G73 on most Fanucs or Mazaks.
    In Edgecam you'd select the Chipbreak cycle when drilling.
    M
    Nov 2010
    65
    I'm using Fanuc 0MD on a Yang Eagle SMV 1000
    I have looked in the manual and possibly I don't understand the G73. Can you explain it? As I read it this command does not withdraw the drill entirely from hole between each plunge?
    My main concern is that the drill moves back into the hole in rapid feed, I would want to set a feed rate for moving down and then a smaller feedrate when actually drilling.
    I appologize for my english, maybe I'm not explaining myself correctly.
    Oct 2010
    21
    for Fanuc
    G21
    G0 G90 G54
    M3 S350
    X100. Y50.
    G43 Z100. H1
    G98 (G99 Option) G83 Z-68. R1. Q0.5 F2.
    X-100.
    Y-50.
    X100.
    G80
    G91 G28 Z0.
    M30
    if you use G99 code while tool is going new position to drill firtly (before new position)
    tool must go up R position (Z=5) if you use G98 tool must go up G43 position (z100)
    Aug 2006
    6
    Hej lene.
    Jeg kan anbefale et bor fra Hoffmann varenummer 122305 som klarer 67 hrc det skulle du kunne køre 16 Vc med. og brug G83 og Q1 så skulle det gerne virke. husk at bruge den lave ildgang 5% eller hvad du har til rådighed.
    m.v.h
    henrik
    Aug 2006
    6
    Prøv med 850 omdrejninger og en feed på 75
    Nov 2010
    65
    Henriktrolle, I will not be able to get to 63mm depth with that drill, but I was adviced to use 122536 which looks like to be just the longer version of that drill. The problem is that aldready 2 drills have broken using the G83 and I only make it to 20mm, how will it go at 60? I'm using much lower feeds and speeds but productivity is not my problem, I just want to make sure the drill makes it. Is it possible to go too slow?
    May 2004
    4519
    The clearance amount for the drill to rapid to before begin next infeed is set by parameter in your machine. You can also used a reduced rapid override during this drilling process, such as 25% (which also should be settable by parameter). If you want to feed into the hole at a different feed rate than the drilling feed rate, you will need to write the code for this. There would be several methods to achieve this code based on functions available on your machine.
  1. Peck Drill Cycle G83
    By Sam A in forum G-Code Programing
    Last Post: 02-20-2016, 06:30 PM
  2. Replies: 4
    Last Post: 01-05-2010, 07:27 PM
  3. Peck Drill cycle generated by post??
    By nelZ in forum BobCad-Cam
    Last Post: 12-12-2008, 05:09 AM
  4. To Peck drill or not to peck dril.....
    By Crashmaster in forum MetalWork Discussion
    Last Post: 08-23-2008, 05:33 PM
  5. G83 peck Drill cycle
    By Vaughan in forum G-Code Programing
    Last Post: 03-19-2004, 06:11 PM
