603,326 active members*
2,997 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Need help wiring VFD to UB1 breakout board
Results 1 to 15 of 15
    Dec 2018
    9
    Question Need help wiring VFD to UB1 breakout board
    Hi everyone,
    I would be very grateful if you could give me some advice how to wire my Siemens Micromaster 440 to my UB1 breakout board (UC300ETH) so I am able to control the speed with the analog output.
    Please find attached two pictures.
    I would connect:
    Micromaster UB1
    +10V ---------> AH1
    ADC1- ----------> AL1
    ADC1+ ---------> AO1
    0V to ADC1-
    Is this correct? What does the ? 4.7 k? in the Micromaster picture mean?
    Kind regards
    Dec 2003
    24260
    Re: Need help wiring VFD to UB1 breakout board
    4.7k is for an external pot, if using a system with a analogue output, then it would be A01 & AL1 if your board requires a supply, then you would connect the AH1.
    Al.
    Albert E.
    Dec 2018
    9
    Thank you very much for your reply. Good to know that 4.7k is for an external potentiometer.
    Ok then the correct wiring should be just:
    Micromaster UB1
    +10V ---------> AH1
    Dec 2003
    24260
    Yes.
    Al.
    Albert E.
    Dec 2018
    9
    It does not seem to work. Could it be possible that I have to connect pin 2 of the VFD (0 V) too?
    Parameter P1000 = 2 which means ADC setpoint
    Thank you very much for your help!
    Dec 2003
    24260
    Use pin2 in place of pin4.
    Al.
    Albert E.
    Dec 2018
    9
    Thank you very much for your help! So far it did not change anything which is really strange for me
    Jun 2015
    943
    Quote Originally Posted by hl68fx View Post
    Did you start the VFD at all? All VFDs need a start signal, it can be an digital input of the VFD or a command (button press) on the control panel of the VFD.
    You can program the start signal source usually in a parameter of the VFD.
    It will not start with just the analog signal!
    Dec 2018
    9
    Yes it starts when I use the M3 command in UCCNC or hit the button on the UCCNC GUI. Also reverse is working. But it is only running with the minimum frequency of 30 Hz (minimum frequency parameter). I get ~48Hz when I connect pin 2 and pin 4.
    Mar 2003
    35494
    Measure the voltage coming from the UB1 and make sure it's correct.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Nov 2018
    14
    I'm running the UC300 + UB1 and trying to get speed control of my VFD. It will start/stop with the K2 relay but the 12v sent to AH1 comes out of AO1 regardless of whether the spindle is on or off and does not change with speed. Any ideas why?
    Mar 2003
    35494
    Send an email to CNC Room. He should have an answer for you.
    Gerry
    Oct 2016
    66
    Curious to know how you end up connecting it. Please update the thread once you have a solution from CNC Room. Thanks
    Nov 2018
    14
    My problem was in the wiring harness. The V+ from the VFD was lost before making it to the UB1.
    Dec 2018
    9
    I was also able to solve my problem thanks to the support from cncroom! I had minimum frequency at 50 Hz, maximum frequency at 200 Hz, but parameter 2000 was also at 50 Hz. So it was not possible to change the frequency to anything else than 50 Hz. Now everything works like a charm
    I recommend everyone to first use a potentiometer until everything works.
    Kind regards
  1. Need wiring of this Breakout board and ID
    By Barefootboy4 in forum Automation Technology Products
    Last Post: 12-27-2017, 10:49 PM
  2. wiring without Breakout Board
    By tpsimer in forum DIY CNC Router Table Machines
    Last Post: 02-16-2017, 09:02 PM
  3. Breakout board wiring help!
    By frostyshoal in forum DIY CNC Router Table Machines
    Last Post: 05-08-2013, 03:05 AM
  4. Wiring Breakout Board Questions
    By Dingo745 in forum Xylotex
    Last Post: 03-31-2008, 08:47 PM
