586,036 active members*
3,457 visitors online*
IndustryArena Forum > Community Club House > Computer Technology > USB, RS232, PARALLEL etc > Need help with a buzzing Glentek GM6000 (Fadal 6030)
    Sep 2016
    9
    This motor is on a Fadal 6030 (1998).
    I just replaced the tachometer and the resolver (both new) on the X axis servo motor (Glentek GM6060-50 DC).
    After reassembly, it seem to function fine, but when we mount it on the ball-screw and move it, periodically a buzzing noise comes from the motor.The noise only occurs when the motor is stopped. It is random and not related to any position or direction.
    Everything seem to work fine, movement and positioning accuracy is OK. There are no errors in the system.
    The ball screw moves freely and is able to be spun by finger tips.
    When the motor is removed from the machine, we cannot recreate the noise by putting load/pressure on the motor by hand.
    I have taken the motor apart multiple times trying to find what may be the cause, but everything seem to be in it proper place, move freely, bearings look and feel OK.
    We have swapped it with the Z axis motor to check if there is a drive issue, but the noise stayed with the motor.
    If anyone had a similar experience with a solution.... feedback would be much appreciated.
    Aug 2009
    1573
    Re: Need help with a buzzing Glentek GM6000 (Fadal 6030)
    ...there are some Service programs stored on the eprom maybe help you... try TA,2 at the Command line to load them.
    https://flintmachine.com/images/uplo...e_Programs.pdf
    DJ
  1. Fadal 6030
    By jon_fallon in forum Want To Buy...Need help!
    Last Post: 12-22-2010, 01:37 PM
  2. fadal vmc 15 axis amplifiers buzzing
    By dougputt in forum Fadal
    Last Post: 02-11-2010, 02:38 PM
  3. Anyone interested in a used Fadal 6030
    By JoBwan in forum Want To Buy...Need help!
    Last Post: 03-13-2008, 06:15 PM
  4. Moving Fadal 6030
    By 5th-axis in forum Fadal
    Last Post: 01-04-2008, 06:01 PM
  5. Reman Fadal 6030
    By redman in forum Fadal
    Last Post: 11-23-2007, 08:31 AM
